Resultados 1 al 10 de 10
Tema: Huddig 1260B
    Oct2008
    Linares
    Predeterminado Huddig 1260B
    Os presento es modelo que nada mas verlo me a encantado:
    Caracteristicas tenicas:
    Engine Cummins turbocharged diesel engine
    Model QSB 6,7 stage III
    Power output 116kW (152 hk) vid 1900 rpm
    Type Straight 6-cylinder water cooled
    Cylinder volume 6,7 l
    Torque 662 Nm vid 1100 rpm
    Transmission
    Hydrostatic.
    Gearbox with 2 gears
    Speeds 1st 0-10 km/h low ratio
    Speeds 2nd 0-42 km/h high ratio
    The transmisson system is separated from the operating hydraulics.
    Axles
    ZF
    Automatic differential brake with planetary hub reduction gears.
    Wheels
    Standard, front and rear 520/70x34
    Brake system
    Transport brakes: Servo assisted disc brakes.
    Parking brake: Spring applied disc brake.
    Service brake: Automatic engagement of transport brake when stationary. (automatic function can be disengaged)
    Steering System
    Hydrostatic orbitrol control system with dual cylinders in the center pivot.
    Steering angle ±32°
    Frame oscilliation ±8°
    Electrical system
    Voltage 24V
    Batteries 2x12V, 110Ah
    Generator output 70A växelström
    Starter motor output 5,8 kW
    Hydraulic system
    Load sensing hydraulic with variable axial piston pumps, 60cc+ 100cc (connected to stepped-up pump distribution box provides a total 174cc). The hydraulic system is prepared for Huddig approved environmentally compatible hydraulic oils.
    Operating pressure: 23,3 MPa (233 bar)
    Nominal max flow at 1 000 rpm 176 l/min
    Nominal max flow at 1 500 rpm 264 l/min
    Nominal max flow at 2 000 rpm 352 l/min
    Weight (incl buckets): 12 850 kg
    Volumes dm3 (l)
    Oil engine 15
    Cooling system 20
    Fuel system 160
    Hydraulic oil tank 185
    Hydraulic system total 340
    Hydrostatic incl tank 30
    Hydrostatic tank 20
    Gearbox 3
    Front and rear axles
    Differential och hub reduction 24
    Parallel linkage loader
    Maximum lifting force 61.5 kN (6150 kp)
    Max breaking force at bucket edge 60 kN (6000 kp)
    Recommended bucket volume, soil 1-1,4 m3
    Recommended bucket volume, light materials 2-2,5 m3
    Backhoe
    Breakout force at bucket edge 103 kN (10300 kp)
    Digging force at bucket pivot 63 kN (6300 kp)
    Lifting force at max reach without bucket 19,1 kN (1910 kp)
    Maximum slewing torque 3700 kpm
    Recommended bucket volume approx. 350-450 l
    Oct2008
    Linares
    Predeterminado Respuesta: Huddig 1260B
    Mas fotos:
    Oct2008
    Linares
    No os recuerda a la VOLVO BM EL70
    Unos videos aunque sean de el modelo 1160, son las dos practicamente iguales:
    Ver video desde Origen
    As Pontes (La Coruña)
    Jan2009
    barcelona
    Maquinón no?
    Me gusta !!
    Nov2010
    Talavera de la Reina
    Predeterminado Re: Huddig 1260B
    pero que buena pinta tienen estas maquinas.
  9. #9
    Apr2011
    Cadiz
    la de cadenas es guapisima y se ven fuertes estas maquinas.
  10. #10
    May2011
    cadiz
    ami me encantan estas retrocargadoras de ruedas grandes lo k creo no haber visto en la retro brazo extensible yo se k la volvo el 70c tenia extensible pero estas maquinas creo k no o por lo menos no lo he me fijado yo en si ficha tecnica bien
  1. Huddig 1260C
    Por osodrogui en el foro Huddig
    Respuestas: 17
    Último mensaje: 20-03-2013, 18:35
  2. Huddig 1260B
    Respuestas: 6
    Último mensaje: 06-07-2012, 11:24
  3. Huddig 760
    Último mensaje: 11-06-2011, 15:52
  4. Huddig 1260 w Remote Control
    Por osodrogui en el foro Controles remotos para maquinas
    Respuestas: 6
    Último mensaje: 01-06-2011, 23:12
  5. Mixtas Huddig
    Respuestas: 5
    Último mensaje: 20-05-2011, 01:13
