Resultados 1 al 3 de 3
    As Pontes (La Coruña)
    Predeterminado Nueva Volvo EW230C
    Excavadora sobre ruedas Volvo EW230C
    The new Volvo EW230C wheeled excavator offers superior stability in heavier lift operations.
    The EW230C from Volvo Construction Equipment is built around a new, more robust platform, which is designed to ensure the stability needed to manage bigger loads, for heavy lifting applications, such as laying big pipe for drainage projects, or hard digging.
    Following the recent launch of the EW210C, a benefit of this platform for a machine in this 20t weight class, is that its design ensures that the rear axle weight, when fitted with the standard counterweight, is below 12t – making it approved for road travel between sites.
    A heavier counterweight is also available for applications not requiring the machine to be moved on the road.
    With the standard counterweight, the EW230C weighs 21.6-24.3t, depending on machine configuration. (23.1-25.6t with the heavier counterweight.) A choice of 5.7m mono or optional articulated two-piece boom is available.
    The EW230C is powered by a Volvo D6E EHE3 diesel engine, developing 125 kW/168hp net at 2,000 rpm, delivering power where it is needed. When required for mass excavation work, or in heavy lifting applications, the EW230C has a lift capacity among the best in its class, optimising performance and productivity. The EW230C on display at Intermat 2009 is fitted with Volvo’s automatic lubrication system, which not only ensures correct lubrication, but also reduces lubricant use by 50%.
    This Volvo wheel excavator include those additional features :
    Access to the superstructure via steps provides for easy servicing and routine maintenance checks, to minimise down time.
    New and higher capacity cooling module.
    Load-sensing hydraulic system features two pumps – one for the attachment and travel and a second, closed-loop slew pump.
    Slew ring from the larger EC240C, for increased strength and durability in tough working conditions.
    Larger hydraulic cylinders.
    Digging forces 10-15% greater than on the EW210C.
    Last but not least, and in common with all Volvo excavators, 95% of the machine is recyclable. As one of Volvo’s core values, Environmental Care is central to Volvo’s thinking when it comes to designing, manufacturing and operating machines.
    www.volvoce.com/press
    Predeterminado Respuesta: Nueva Volvo EW230C
    Utilizando un traductor automatico:
    La nueva excavadora de ruedas Volvo EW230C ofrece superior estabilidad en las operaciones de levantamiento de peso.
    El EW230C de Volvo Construction Equipment está construido en torno a una nueva y más sólida plataforma, que está diseñado para asegurar la estabilidad necesaria para gestionar grandes cargas, para aplicaciones de trabajo pesado, como por grandes proyectos de tuberías para drenaje, o difícil de excavar.
    Tras el reciente lanzamiento de la EW210C, un beneficio de esta plataforma de una máquina en esta categoría de peso 20T, es que su diseño garantiza que el peso del eje trasero, cuando se adapta a la norma contrapeso, es inferior a 12 t - lo que aprobó para los desplazamientos por carretera entre los sitios.
    Un pesado contrapeso también está disponible para aplicaciones que no requieren la máquina que se trasladó a la carretera.
    Con la norma contrapeso, la EW230C pesa 21,6-24.3t, dependiendo de la configuración del equipo. (23,1-25.6t con el más pesado contrapeso.) Una selección de 5.7m opcional mono o dos piezas articuladas auge está disponible.
    El EW230C es alimentado por una Volvo D6E EHE3 motor diesel, el desarrollo de 125 kW/168hp neto en 2000 rpm, entregando el poder cuando sea necesario. Cuando la masa necesaria para trabajos de excavación, o en aplicaciones de trabajo pesado, el EW230C tiene una capacidad de elevación entre los mejores en su clase, optimizar el rendimiento y la productividad. El EW230C en la exhibición en Intermat 2009 Volvo está equipado con sistema de lubricación automática, que no sólo se garantice la correcta lubricación, sino que también reduce el uso de lubricantes en un 50%.
    inglés
    Esta excavadora de ruedas Volvo incluye las características adicionales:
    El acceso a la superestructura a través de medidas para facilitar la prestación de servicios prevé el mantenimiento de rutina y controles, para minimizar el tiempo de inactividad.
    Nuevos y de mayor capacidad de enfriamiento del módulo.
    Detección de carga hidráulica del sistema cuenta con dos bombas - una para la conexión y gastos de viaje y una segunda, de circuito cerrado bomba mató.
    Ángulo de giro del anillo de la mayor EC240C, para una mayor resistencia y durabilidad en las condiciones de trabajo difíciles.
    Ampliar los cilindros hidráulicos.
    La excavación de las fuerzas de 10-15% mayor que en el EW210C.
    Por último, pero no menos importante, y en común con todas las excavadoras Volvo, el 95% de la máquina es reciclable. Como uno de los valores fundamentales de Volvo, al medio ambiente es fundamental para el pensamiento de Volvo en cuanto a diseño, fabricación y funcionamiento de las máquinas.
    Jan2009
    Santa Colom de Queralt
    Unos Videos de la Volvo.(es un manual video de la maquina)
    http://www.youtube.com/watch?v=pPQWZm3EYBcYouTube - Introduction to the Volvo Wheeled Excavator Operator Videos (Part 1 of 16)[/video]
    http://www.youtube.com/watch?v=F36P5gdQAhwYouTube - Before working with a Volvo Wheeled Excavator (Part 2 of 16)[/video]
    http://www.youtube.com/watch?v=ZRofO9TyQtwYouTube - Cab features of a Volvo C-Series Wheeled Excavator (Part 3 of 16)[/video]
    http://www.youtube.com/watch?v=10PY-6doWpoYouTube - Travelling off-road with a Volvo Wheeled Excavator (Part 4 of 16)[/video]
    http://www.youtube.com/watch?v=DvKtkVsUFSEYouTube - On-Road travelling with a Volvo Wheeled Excavator (Part 5 of 16)[/video]
    http://www.youtube.com/watch?v=k4TRL60E8gMYouTube - How to prepare a working place for a Volvo Wheeled Excavator (Part 6 of 16)[/video]
    http://www.youtube.com/watch?v=G4R-tVQb_DUYouTube - How to load a truck with a Volvo Wheeled Excavator (Part 7 of 16)[/video]
    http://www.youtube.com/watch?v=iNPYiJasMjEYouTube - Lifting instructions for Volvo Wheeled Excavators (Part 8 of 16)[/video]
    http://www.youtube.com/watch?v=oWgbq9arUrcYouTube - How to grade with a Volvo Wheeled Excavator (Part 9 of 16)[/video]
    http://www.youtube.com/watch?v=ELZJgQnLYxcYouTube - How to use S1,S2,S3 quick fit on a Volvo Wheeled Excavator (Part 11 of 16)[/video]
    http://www.youtube.com/watch?v=bWfDETpNCwsYouTube - Adjusting the play of the quick fit on Volvo Wheeled Excavators (Part 12 of 16)[/video]
    http://www.youtube.com/watch?v=6zxHN42qvOoYouTube - How to use a S6 type quick fit on a Volvo Wheeled Excavator (Part 13 of 16)[/video]
    http://www.youtube.com/watch?v=7Z53xGnS_owYouTube - How to use the universal quick fit on a Volvo Wheeled Excavator (Part 14 of 16)[/video]
    http://www.youtube.com/watch?v=jxF-r4RbqPkYouTube - What to do with a Volvo Wheeled Excavator after work (Part 15 of 16)[/video]
    http://www.youtube.com/watch?v=u9fLl6EuIbAYouTube - Loading a Volvo Wheeled Excavator on a truck (Part 16 of 16)[/video]
  1. Nueva Campaña de Seguridad Volvo
    Último mensaje: 24-08-2015, 15:01
  2. Nueva Campaña de Seguridad Volvo
    Último mensaje: 03-09-2014, 11:55
  3. Nueva Campaña de Seguridad Volvo
    Último mensaje: 11-09-2012, 13:30
  4. Nueva Campaña de Seguridad Volvo
    Último mensaje: 05-09-2011, 17:50
  5. La Nueva gama de Volvo Trucks en IAA
    Por Ramon en el foro Volvo
    Último mensaje: 27-12-2008, 20:09
